May the 4th be with you!
Upgrade any cheap cosplay blaster with our sound generator kit to recreate those epic Star Wars scenes at home! Happy Star Wars day and happy making!
How to?
Start by buying a simple cosplay blaster that you can screw open easily. Then make the siren sound generator kit but adjust the following:
- Do not solder the switch onto the board. Instead, use some electrical wires and make it long enough so you can mount the switch outside of the blaster. Check the picture above to make sure you are doing it right. Use hot glue to keep it in place.
- Do not mount the battery onto the board either. Instead, place it somewhere where it fits inside the blaster too.
- If you want the sound to be good, drill some holes into the plastic of your blaster where the speaker is going to be.
- Lastly, make sure that the siren sound generator is set to the correct sound before you close everything up!
