Say Hello to these Extra-Large Summer Soldering Kits!
Summer’s starting early thanks to these summer soldering projects
🍍 Looking for a fun DIY summer project? Assemble this extra-large figurine and make its LEDs shine all the colours of the rainbow! Ideal for both beginners and advanced makers!
In order to assemble these kits, you will need to solder all components onto the striking gold or copper-plated circuit board. The components include fancy RGB LEDs that have a special diffused effect. Once the soldering work is finished, the LEDs will perform 5 different light effects. The onboard ATtiny chip is pre-programmed with some sparkling LED effects, so your kit will work once you power it with the included adaptor.
Find the full manual in the manual and downloads tab of this product page.
Assemble one or more of these extra-large figurines and make their LEDs shine all colours of the rainbow! Ideal for both beginners and advanced makers.
🦩 In order to assemble the extra-large figurines, you will need to solder all components onto the unique gold plated circuit board. The components include fancy RGB LEDs that have a special diffused effect. Once the soldering work is finished, the LEDs will perform 5 different light effects. The on-board ATtiny chip is pre-programmed with some basic LED effects, so your kit will work once you power it with the included adaptor. Or you can choose to write your own code based on the available example code.
Find the example code and full manual in the manual and downloads tab of this product page.
Enjoy the bright RGB LEDs. 🍸️
- XL-size & gold plated circuit board (PCB) in the shape of a summer cocktail
- 19 addressable (programmable) RGB LEDs – WS2812
- 14 x 5 mm RGB LEDs
- 5 x 8 mm RGB LEDs
- ATtiny85
- onboard push button
- USB A to USB B cable for power supply
- wooden holder
- complete manual and video available in 5 languages
- example code for Arduino available
- educational & fun for all ages and skill levels
- not included: soldering iron, soldering tin, pliers and an soldering mat
“Enjoy all the colorful RGB LEDs of these 4 extra-large soldering kits!”
What’s in the box?
Each kit is at least 25 cm high, and will be a flashy eye-catcher in any room. In order to assemble these grand kits, you will need to solder all components onto the unique gold or silver plated circuit board. The components include fancy RGB LEDs that have a special diffused effect. Once the soldering work is finished, the LEDs will perform 5 different light effects. The on-board ATtiny chip is pre-programmed with some basic LED effects, so your kit will work once you power it with the included adaptor. Place the finished kit into the wooden holder, et voila!
Find the full manual in the manual and downloads tab of each product page or inside the box
