Retro Soldering Kits
Go back in time and learn about electronics thanks to these five retro designed soldering kits for kids!
These five nifty kits are educational DIY projects that need to be soldered.
Soldering these kits is easy and fun, and you will learn more about electronics in the process. Each kit has a few LEDs that will flash different animations.
General features & specifications
- multiple colored LEDs
- on/off switch
- retro designed PCB
- mounting hole
- 1 x candle flicker LED
- 3 V – 1 x CR2032 power supply (not incl.)
Can’t get enough? Then get one of our sets! They include two of five retro kits, so be sure to explore all of them!
Retro Air Balloon – Educational Soldering Kit
This nifty kit is an educational DIY project that needs to be soldered. Soldering is a technique used to connect electronic components. Soldering this kit is easy and fun, and you will learn more about electronics in the process. Once finished, the LEDs on the kit will shine and you will have a neat gadget.
This particular kit is shaped in the form of a Jules Verne style hot air balloon that can either be hung thanks to a little mounting hole in the top, or it can stand on its own.
- 6 x orange LEDs
- on/off switch
- retro designed PCB in the shape of a hot air balloon
- mounting hole
Retro Zeppelin – Educational Soldering Kit
This particular kit is shaped in the form of a Jules Verne style zeppelin that can either be hung thanks to a little mounting hole in the top, or it can stand on its own.
- 9 x green LEDs
- on/off switch
- retro designed PCB in the shape of a retro zeppelin
- mounting hole
Retro Submarine – Educational Soldering Kit
This particular kit is shaped in the form of a Jules Verne style submarine that can either be hung thanks to a little mounting hole in the top, or it can stand on its own.
- 9 x green LEDs
- on/off switch
- retro designed PCB in the shape of a retro submarine
- mounting hole
Retro Bicycle – Educational Soldering Kit
This particular kit is shaped in the form of a Jules Verne style bicycle that can either be hung thanks to a little mounting hole in the top, or it can stand on its own.
- 9 x yellow LEDs
- on/off switch
- retro designed PCB in the shape of a retro bicycle
- mounting hole
Retro Biplane – Educational Soldering Kit
This particular kit is shaped in the form of a Jules Verne style biplane that can either be hung thanks to a little mounting hole in the top, or it can stand on its own.
- 6 x yellow LEDs
- on/off switch
- retro designed PCB in the shape of a retro biplane
- mounting hole
