MOSFET SET
MOSFET SET
€24,90
Switch and amplify your electronic signals in high power applications with this set! It includes the IRFZ44N, IRF540N, IRFP460, FQP47P06, IRL540, IRLZ44, NTP60N06L, FQP27P06, a fast speed insulated gate bipolar transistor IGBT 17A and an octal bus transceiver with 3-State output.
Dit product is een vervanging van: VCS103
- 1 x N-channel power mosfet IRFZ44N ID 49A
- 1 x N-channel power mosfet IRF540N ID 33A
- 1 x N-channel power mosfet IRFP460 500 Vdc 13A
- 1 x P-channel power mosfet FQP47P06 ID 47A
- 1 x logic-level gate drive power mosfet IRL540 ID 20A
- 1 x logic-level gate drive power mosfet IRLZ44 ID 36A
- 1 x logic-level gate drive power mosfet NTP60N06L ID 60A
- 1 x logic-level gate drive power mosfet FQP27P06 ID 27A
- 1 x logic-level gate drive power mosfet NDP6020P ID 24A
- 1 x fast speed bipolar transistor insulated gate IGB 17A
- 1 x octal bus transceiver with 3-State output
- 1 x euro hole plastic box (140 x 70 x 30 mm)
Gewicht | 72 g |
Afmetingen | 2,80 × 7,00 × 15,50 cm |
Soldering | |
Electronics | |
Coding | |
Mechanics |
