Make a Micro:Bit controlled fan!
- March 28, 2019
[vc_row][vc_column][vc_column_text]Micro:Bit is all the rage and so is this handheld fan! It’s the ideal project for those of you who want to start experimenting with Micro:Bit.
The fan can be turned on and off by using the buttons on the Micro:Bit and the development board will show whether or not the fan is on or off as well. The case is made with a 3D printer, but you can get creative with cardboard or any other DIY material. Just make sure to check the size of the DC motor so it fits nicely and can’t fall out.
Find the tutorial on our manual platform and check out some of our Micro:Bit items below![/vc_column_text][/vc_column][/vc_row][vc_row][vc_column]
